Old 11-08-2018, 08:27 AM
Originally Posted by SeaPlusPlus View Post
Only problems I've read about the honeycomb is that any cut edges need to be filled with thickened resin and it doesn't take a screw, so you need to cut out any areas that require a screw and replace it with wood or other high density material.
Mounting things on vertical bulkheads requires thru bolts most of the time but as long as you glass the deck sufficiently you won’t have any problems. If you are screwing down consoles, leaning posts or deck hatches you just need to make sure add a little extra glass and maybe some composite strips underneath before you lay the deck. It is well worth the weight savings and strength using honey comb.
