Old 11-28-2018, 08:12 PM
The lams are plenty stout... But trying to do all those giant wide pieces in the boat is gonna be a royal pain unless youve got 3 guys who know what theyre doing.
I would get them built/shaped and glass them outside the boat. Then do your tabbing/extra capping afterward.
I would wrap 2x1708 to start before going into the boat. Then in the boat 2x1708 tabs followed by your triax tab (widths depending on stringer height and relation to triax cap overlap). Then do your triax cap getting a nice overlap over the tabbing. Wider tabs first...
Wet the tabs out on a table, roll them up mat side out, roll back into the boat and hardroll. Let gravity wet it out for you on the table, and you also wont be bathing in resin trying to wetout those monster pieces on vertical stringer sides inside the boat!
Same when you do the stringers outside the boat. Sometimes ill run some 3" drywall screws down a plank and set a long piece like that on edge when i want to glass both sides and cap it (top up of course) onto the screws which will hold it vertical. Then wet out on a table, roll up, roll onto stringer, done...
Just something to think about, hope it helps... Chris
