Old 01-30-2019, 08:27 PM
Originally Posted by Deathfromabove View Post
What is the right way to lay cloth/tab at the transom rakes/chines at the underside/outside of the hull when you remove the transom totally without build up on the bottom rear of the transom to hull area?
When the boats upside down! lol
Grind out a taper where your overlaps will be. Roundover the corners just enough to wrap glass around.
You can use a straightedge to see how your taper is while youre grinding, ideally it will be just a bit deeper than the thickness your new glass will be built up. You dont want the new glass totally flush with the hull or it will print thru badly, you wanna leave a lil bit of a low for fairing compound/primer to build up...
