Old 02-14-2019, 09:56 AM
Rybones Rybones is offline
Thank you for the edit Chuck.
As you can see in the pictures it has a seam along the side and top back Edge of the motor mount portion indicating its two piece construction. I imagine core material would be laid up along the back Edge of tub portion and then capped by the swim platform. Any void, no matter how small between the coring material in the top front portion of the cap would be enough to create stress cracks in that seam overtime. Considering that bracket been on that boat since about 2002 so we're looking at 16 years of stress without knowing Construction it's hard to determine if it's something to be concerned about or not. But considering that it's to part construction with a seam that has constant direct exposure Plus mounting holes drilled through it, there is a real potential for degradation of core material due to moisture. Dating to 2002 core material is likely wood.
