Old 02-26-2019, 08:08 AM
Originally Posted by duncansf75 View Post
@uncleboo - So you're not worried about the potential of water getting into the stringer? I know the 5200 will seal it up but over the years I'm sure some water will get in and rot the wood or even the foam. Should I throw some epoxy in the pilot hole before I put the screw in?
Not on top of the stringer. Mine had holes in the top from one end to the other. If you get that much water in the bilge, you got bigger problems. Anything you do to prevent water intrusion is good. If your deck coring is solid, it'll hold with the right size screws and sealant/adhesive. I had a Todd leaning post that mounted on a single pedestal, original from the factory. I used to sit on it while running, 200 lbs. and it never even creaked. was only screwed in on a bed of silicone into the original deck, of course.
