  #84
Old 03-07-2019, 07:54 AM
Kraken Kraken is offline
Rolling gelcoat on the gunnels and interior is a great option if you plan on not worrying about chips and dings. I use my boat with no regard to scuffs, scrapes and dings and it really makes using the boat much easier as you can always fix anything that happens which will always occur.
One thing I will recommend is that you choose a standard color for these areas from a reliable dealer. This will make touch up much easier. Also I would recommend using Duratec additive instead of wax or surfacing agent. Duratec adds uv protection and gives you a durable, glossy finish that cleans up well. The only issue is that you will need to apply multiple coats to get the thickness you need on the high traffic areas on the gunnels and transom cap. I also keep a small container of touch up mixed in the refrigerator. When I have a chip I just mix a drop or two of premixed duratec and gelcoat with a drop of hardener and dab it in with a small brush.
Thanks Moose I’m not one to flip out if I get a scratch. If the boat isn’t getting beat up we are not using it hard enough. I do want it to look reasonably good and be easy to clean. I like your comment of selecting a standard color the make it easy to repair. Between spearguns tanks and coolers I will be busy.
Did you mix duratech with each coat or just the top layer? Also did you did any sanding and buffing?
