Originally Posted by Rybones
So if you have ball checks there that would imply that the deck scuppers run through the rear, hence deck work of some sort has been done..? Although also see what looks to be small original self bailing deck scupper wells, albeit covered in leaves in one of the pictures you posted. Anybody have an idea whats going on there? Did they just close up the original scupper port on bottom and rout it to a hose through the transom? (maybe the cap was off but whatever was done was just phoned in).
Well you got me I just assumed they where just a screw on kit. I did not realize they original went thru the bottom I know for sure at some point the rear cap was cut to repair the transom cause I can see it cut in the cap. The Shop 2 guy said they used "high quality glass" and did a good job from the inside. Both the deck scupper wells and bilge run out the transom.
The dude I got it from I think said the guy before him i think did the transom and he pulled the whole cap to repair floors.
