Old 03-26-2019, 09:58 PM
Joe R Joe R is offline
its the same as on my 21 ...Has a seacock through hull that you open and then turn on the pump that is attached to it to fill the well...there is another pump that is at the bottom of the well to pump out the well when you want to empty it...then there is a plug higher up in the well that you can pull out to keep the water level up to that plug drain...you can use it many ways...the only PITA is the well fills with water after it rains and you have to pump it out..that seacock valve is a pain to reach so I keep mine closed and just fill mine with a bucket ...I just changed my lower pump in my well yesterday PITA tight down there...
Joe R
21 SeaCraft 1998 with 200 Optimax 2015
Susie 2
Joe R
