Thread: Suzuki ?
Old 03-28-2019, 09:33 PM
Explanation
https://www.go-fast.com/prop_slip.htm
"Slip is never a negative number, and will range from 5% on a light cat to 25% on a heavy workboat. Most hi performance applications will be between 7 and 12 percent."
25% - 30% slip at Cruise and Wide Open Throttle (WOT) puts you into the work boat (Barge) category.
The 3.6L V6 models use a 2.29:1 ratio. (I made the assumption you have the 3.6L w/2.29 ratio when calculating the slip)
The 4.0L V6 models use a 2.08:1 ratio. (if you have the 4.0L with the 2.08 ratio, slip numbers increase to 33% and 36%)
Your prop is a 17P
Plug the numbers into the prop slip calc below.
Prop Slip Calc
https://www.go-fast.com/Prop_Slip_Calculator.htm
