Old 04-10-2019, 07:52 AM
Had a member ask me about the dims of the brackets I build or built so here is a ruff sketch of approximate Dim's of the one I built for a 20 SeaCraft hull. It is slightly different from the hermco. This one mounts lower, and has the swim platform lower as well. Keeps the lower outboard bolts below the swim platform but just barely. 25" shaft motor will end up 4.5" above the bottom depending on what holes you use. 22" of set back and will clear a mercury 2.5 outboard fully tilted by 1/2" clearance.
