Old 04-10-2019, 04:05 PM
Originally Posted by take a potter View Post
Man you all are great! Thank you so much.
Now I just need to figure out how to make it work with a 25" shaft on a 23' cc.
That is the most technical part of doing one. Making the height right for the shaft length and keeping the floatation chamber and swim platform low to the water. I know you want to mount the bracket low as possible but when doing so the lower outboard mounting bolts will land about where the swim platform is. If not careful outboard mounting heights and overall bracket height you may end up with all four bolts above the platform or when you mount the motor high as the bottom bolts allow your engine is still to low in the water...
