Old 05-14-2019, 01:34 PM
IslandMarineGroup IslandMarineGroup is offline
Default Pictures are nice
The console had over 200 holes drilled in it over the years. I've now fixed them all, recored the top where the compass goes and where the steering wheel mounts. I plan to glass over where the instrument box used to be. I may also glass the aft facing surface and let the next owner either cut out an access hole or mount a door.
The boat made an abrupt stop and damaged the bow. This will take some glass work to make it look right.
The deck's been cut out and it was full of leaves underneath. I want to figure out a way to close out the rod storage boxes to keep debris from getting in between the hull and deck. The tank is out. I'll test it and sell. I have big pallet that it will fit on nicely for OTR shipping. Curious the tank had no mounting tabs to screw to the stringers. It was held in with only foam. We were dreading the removal but the foam was hardly stuck to the aluminum and it came right out. I can have tabs welded on the tank if the buyer wants them by a good aluminum fab shop.
