Looks like the bubble will end up right where the bracket will mount up at. You may want to grind it out and refinish that spot. Probably a delaminated spot or air pocket of sorts. If you clamp the bracket to that spot it may pull it in and make it not too noticeable but now is the time to fix it as you don't want to have to later after paint....
