Old 06-15-2019, 07:10 PM
bbh57 bbh57 is offline
Check and double check... in the pictures it appears that the top of the bracket is a 90 degree angle to the bolt on face. ( most bracket built at slight difference. 15 degrees or so.) the transom angle will make it necessary to mount it higher. Curious as to how the motor bolts to bracket. Agree with Don, Cav plate 3 to 4 inches above plane of hull. have mounted my last 2 boats that way. worked fine.
