Old 07-01-2019, 12:56 PM
steel686 steel686 is offline
Not much to brag about but the sides have been cored and laminated. I dropped the liner back in and screwed it off while the skin cured and feel better about holding the shape. I carved off the top of the stringers and popped out some wet foam. It was odd that the port side came out in two pieces like an ice cube and the starboard side had to be chiseled out in small chunks. Anyway, cleaned up the inside and ground a bevel on remaining vertical glass to tie caps back in after pouring new foam. The rigging tube holes under the console have always bothered me where they fell under the flange. I reworked the console and shortened the plan for the tank so controls and hoses will run through the back of the coffin. I borrowed a detail from Strick's scupper detail and glassed new tubes to run through stringers. Also installed new limber tubes from fiberglass handle stock. Trying to pour foam in next two days and be able to patch miscellaneous stringer cutouts, cap with 3x 1708, and then wrap 2x 1708 onto bottom. Liner is almost completely de-cored and will glue up Divinycell and mounting pads for leanpost etc.
