Old 08-06-2019, 03:23 PM
castnetcracker castnetcracker is offline
Optional when purchased or a switch to activate or not? We mostly do watersports now and frequently shut down for letting riders in and out of boat and would not want to have to readjust every time.
Optional based on how you wire the switches. the orange wire from the paddle switches has to have power to operate and light up the indicator for the position of the tabs. When the circuit is broken, the tabs will reset. if you wire this to your ignition source, it will reset when you turn off your key. if you wire this to your fuse block, they will reset when you turn off your main battery switch.
