You should be fine. I have done quit a bit of glass here I live in Boca and I would be more concerned with overheat and gasing causing that will blister in spots in this heat. Use Xtra slow epoxy when it’s this hot. I would suggest u read all the specs on products u are using epoxy,awlgrip etc and understand it well or u could be redoing things or poor bond. Good luck
