Old 01-04-2020, 03:41 PM
FLexpat FLexpat is offline
For some reason I can't see the pics - says invalid album but I would check around the floor drain scuppers first. The brass tubes corrode and start leaking - it takes a lot of water to fill the bilge on a trailer to the point that it leaks out. I had a vague memory of seeing a trickle when mine was in the water so I put the plug in from the outside while it was on the trailer and ran a hose onto the deck - water drooled into the bilge from one of the scuppers before it was an inch deep on the deck...
Pulled it apart - the tube was toast and the wood backing block was rotted mulch
