Thanks for the advise. I drilled some more test holes in the stringers and found some water... figure may as well do it right while I'm at this point. I'll be removing all old foam and adding 2lbs pour foam. I've never used pour foam, how important is it to get the boat level before pouring? From the looks of it puffs up over the forms and is then cut it back down to size so having the boat level isn't important??
