Old 03-18-2020, 10:26 PM
Sprunx Sprunx is offline
Originally Posted by SSPBill View Post
The tank and hatch are definitely smaller on my '72 Seafari compared to my '78. The linked post is an accurate hand drawing of an original Seafari tank. If your has the original tank I believe the procedure is to slide the tank back and lift the front. The taper at the front allows the bottom of the tank to clear the deck.
http://www.classicseacraft.com/commu...8&postcount=11
That drawing is great. I’m not sure if the front of my tank is tapered underneath like that but the rear taper and the pickup, vent, and fill all seem to be correct placement. I thought that would be the procedure just wasn’t sure if I would have enough room on top to get the angle needed to get the front up and over the deck. I also didn’t realize the front may be tapered like that underneath. Thanks for this drawing. Have you ever had yours out on you 72?
