Old 06-10-2020, 08:24 PM
Originally Posted by bassriverdoormatt View Post
Thanks X, I'm making some braces out of the spare penske for the supports. I glued up the transom yesterday and it came out well with one exception. I cut each of the two layers into 4 pieces like UrbanAngler did on his project. On the outer layer, the top piece wasn't clamped properly (oversight on my part). The top is snug with the previous layer but the bottom of it sits proud by maybe 3/16" at the widest. The closer you get to the outside edge, the better it gets. I'm thinking I will cut the resin on the bottom joint and drill some holes to inject resin into the gap then clamp it down. Or should I cut the trouble piece out and just replace it?
Pics? I can’t visualize this. Sorry been busy since last Friday
