Old 07-27-2020, 06:50 AM
Folks get way too wrapped up with CG on a 23’ foot boat. First, Tsunami configuration is already weight forward compared to a CC so my mod didn’t impact weight shift that much compared to the addition of the bracket. The fuel tank was moved forward slightly but fuel weight isn’t static so it varies throughout the day. The biggest weight distribution factor on a small boat is trip loading (ice, gear, people, etc.). This is why I left the port deck clear to place my 250qt cooler anywhere it needs to be to compensate the days particular load. People load is the biggest factor that can be easily adjusted by where they sit or stand while running. Any other weight issue can be adjusted withe the tabs. Again, fixating on static CG on an empty 23’ narrow hull is the least of considerations unless you are hanging too much weight on the stern causing deck draining issues.
