Old 07-27-2020, 02:55 PM
Alot to go over right off the bat!
1. Start with the transom. Two sheets of 3/4 is standard, skip the glass between and just use epoxy/cabosil.
2. Sounds good
3. Sounds pretty far aft...
4. Cross that bridge later
5. Sounds good. Probably need an extra rib over fuel tank on underside.
6.Yes but tab everything
7. yes
8. A: splashwell sounds huge unless im misinderstanding. Shouldnt need even half of that distance to tilt up.
D: ideally yes full height. Depending on what tabs, you may be able to snake wire thru limber holes. Hydraulic have to get creative
