Old 07-27-2020, 07:50 PM
Krich337 Krich337 is offline
Replacing the scupper drain hoses, it was rigged with wire reinforced black rubber hoses with hose clamped to NPT threads (not hose barb connections) on each end. Now I have to replace the cockpit scupper thru hulls with a 2" thru hull connections with 2" hose barb connections and add hose barb connections to the transom scupper valves. BSP what were you thinking, relying on a hose clamp to make a hose over a thread connection water tight.
