Originally Posted by Stephen
My Batteries are located under my center console. I’m not getting enough current to my motor because of corrosion in the junction box. Would y’all recommend moving one battery in the transom, or redo battery cables completely?
It would be different if you were stranded and needed a get home solution. If you know the problem is corrosion, FIX IT, DON’T BAND AID IT. Some CC owners are moving weight fwd, not aft.
