Old 09-10-2020, 06:46 AM
No grave but the Seacraft No grave but the Seacraft is offline
Default 1988 SeaCraft rebuild
So I took most of the holiday weekend off working on the boat to do a little fishing but got back at it on Tuesday. I was able to get the transom doubled up with a layer of 1700 between them. Its been glued, filleted, tabbed and layered with a single sheet of 1700. It will get at least two more layers before it's done. The outboard bracket has received the same treatment except the motor mount is 3 layers of 3/4" coosa thick while the bottom will remain a single layer. The tub will be at least three layers of 1700 inside and out. I will also be adding two stringers inside the tub before the swim platform goes on.
