Old 09-13-2020, 06:00 PM
rcnight rcnight is offline
Jim - 30” is the way to go. I even went up an inch to 31” for some additional vertical adjustment when I did my transom. If you’re going to cut the skin off to get at the core, you might consider going in from the inside. Depending how your deck hatches are oriented, might be less glass work. Also easier to get the tank out and drain your stringers. Just my 2 cents.
