Ok, trying to get on board with the vinyl ester suggestions for the bracket. When I use epoxy the CSM is eliminated except for the exterior faces. My understanding is that CSM with epoxy does little for strength and adds weight. If I go with vinyl ester do I need to put CSM between each layer in other words use 1708 vs 1700? And do I also need to put CSM between each layer of plywood? On the plus side seems like vinyl ester would be easier to use in the colder temperatures.
