Old 10-08-2020, 07:39 AM
Motor height is going to be your first big problem. My 23 Tsunami with a full pipe top and the same df300 can hit 6300 trimmed up @ 50 mph with a light load so your CC should do way better than me.
If you are running a Suzuki 3 blade prop I would urge you to explore other options. If it was me I would get my hands on a standard Merc 4 blade Bravo 1 22" pitch and raise the motor as high as you can mount it. The Bravo will run efficiently much higher than the Suzuki prop and steer much easier.
