Old 10-15-2020, 07:18 AM
You want the bracket low and the power head jacked up a bunch.
That has to be designed into those stoner brackets.
Oh, they did that. Haha.
Denny set the record I think.
4 1/2 up.
Get an aggressive stern lifting prop.
Cheers,
gfs
This^
Most people with brackets cant get their outboard high enough and run out of adjustment. My AV plate is also 4 1/2" above the keel. So mock it up do some math and make sure you can have adjustment at that range. The lower the tub the better, size the outboard leg to work with a low tub height.
