Old 10-20-2020, 06:50 PM
No grave but the Seacraft No grave but the Seacraft is offline
Default 1988 SeaCraft rebuild
I've been bouncing around working on different things here and there as I have time. I have also been putting off finishing the outboard bracket because I couldn't decide on the style of drain plug I wanted to use but I did get the inside of the tub painted. I went with white only because I couldn't find a black bilge paint. The livewell and seachest molds are faired, painted and ready to be waxed, gelcoated and glassed when I can find a full day to get it knocked out. I also, was able to plumb and pour the stringers. I used cheap luan subfloor screwed to the sides of the original stringers and poured 2lb foam right on top of the old ones. They were dry so I didn't bother removing the old foam. I extended them to the bow and raised them roughly 2 inches. They just need a bit more sanding and they'll be ready for 2 layers of 1700.
