Old 10-25-2020, 11:50 AM
Originally Posted by JBASS02 View Post
I used 1/2" 26lbs. Over the fuel tank where the span is the largest there is a second layer on the underside. If I did it again I would do everything except the transom in Divinycell, would have been cheaper. When I was planning out the project I didn't want to mess with doing Coosa inserts where I would be bolting components so I did everything in coosa.
I'm planning on the same coosa but in 3/4 for the deck. I've been told by a couple of builders that the 1/2" flexes a bit on the deck. Are you seeing this at all? Impressive build for sure!
