Old 10-29-2020, 12:39 PM
captsuperfly captsuperfly is offline
been there. I've also found some slightly thickened cab mix on those uneven spots helped me with the voids - instead of grinding too deep around it. I'd just wet the area down with neat resin, pull some thickened resin over the uneven spots and glass over all of it wet. the area where my old engine mounting blocks were was especially rough so it helped me there. Also the side of the stringers (though you've got smooth coosa).
I've been using heat lamps and small sections which has helped. I have some portable heaters too. I have a few more long runs to make before the deck can go on, so I'd like to get it done before I get froze out.
Did you shrink wrap your tent frame?
