Old 11-08-2020, 07:30 PM
No grave but the Seacraft No grave but the Seacraft is offline
Default 1988 SeaCraft rebuild
So I glassed the undersides of the fishbox and outsides of the bulkheads. I also cut down the length of the fix box to 45" because (1) it was probably larger then I needed and (2) I realized I might be able to reuse part of the liner to support the forward storage bin. I had to raise it 2" and forward 4" over factory height because of the raised and extended stringers. I got lucky in that this new position will allow me to glass the bin edges to the little kickout molded above the original attachment point. The bow section of the liner was used work out my gelcoat technique and color.
