Old 01-27-2021, 06:59 PM
take a potter take a potter is offline
Marked the center line of the boat transom and the bracket. Used a squeegee with a small hole drilled in it to mark a repeatable spot on the chine corners. Drilled a small hole and then using a stick with a pencil and screw inserted, struck arcs. Connected the intersections to get the center line.
Got the bracket mounted with just 3 bolts. Wanted it in place to verify the height to trim the clamping board.
Got it trimmed, next step is to template the platform.
