  #60
Old 03-27-2021, 10:45 PM
No grave but the Seacraft No grave but the Seacraft is offline
Default 1988 SeaCraft rebuild
I glassed in preformed battens on the port side to stiffen the hull. I will be reusing the top portion of the cap and glassing it to the hull sides via under gunwale rod holders as well as the bow and transom bulkheads and decks so I'm not sure I actually need to. I bought them early on in this project thinking I would so why not now, right? The front bulkhead is fully glassed in place. It received 6" tabs on the bow side and a full covering on the stern side. I chamfered the corners of the console, rounded the hard edges and set it in place to make sure it would fit properly. I have been going back and forth about what do do for a leaning post. I've been eyeballing the Stryker swing back in aluminum but my brother is trying to convince me to go custom. I must say his does look really good but I don't know that I can justify the extra dollars.
