Old 04-04-2021, 06:28 PM
rdoaner123 rdoaner123 is offline
I should mention, I've been noticing the prop sometimes partially breaks free even when I'm going in a straight line and increase rpms. The prop shaft seems straight, so I'm not sure why this would be
Attached is a picture of the lower unit with slightly positive trim at 3600rpm. I circled the back of the anti-ventilation plate in red. You can barely see it through the water. Should I go up one hole or two?
