Old 05-03-2021, 02:31 PM
Thinking if you mount the tank in the bilge, it will be exposed to more moisture. My coffin has a 1" drain hole in the rear and the hole where the rigging goes through allows it to have some airflow, not much, but, some. I installed inspection plates over the fill hose fitting, sending unit and pick up fittings so I can inspect or vent if it gets moist.
