Old 05-04-2021, 09:49 PM
mazz888 mazz888 is offline
Just got to check my cav. plate 30” bracket and I’m at 5 1/2” above the keel . I’m wondering if the flat bottom vs a v bottom bracket is / would make a difference?
I’m not sure I could raise it that high with a 3 blade prop but the 4 blade likes it.
Thank you for the info I got the tabs moved old holes filled and glassed over. I hopefully can get some gel coat on it soon to finish the process and get it on the water to see what it is like now. I will try to get my hands on a 4 blade to try out. Again thank you everyone for the help I will update faster sea trial.
