Old 08-11-2021, 07:47 AM
SeaChuck SeaChuck is offline
I am sure some 2x4s screwed to the cap and manpower to lift will work. It is not heavy. a few wacks with the sledge helps too
I believe the issue with reinstalling is actually the side walls of the hull flex out a little with the cap being off. I have seen others using 2x4s screwed side to side , inside, holding the side walls together.
I used two long ratchet straps and flexed the side walls back inward for the reinstall.
hope that helps
