Old 09-12-2021, 09:00 PM
G10 plate epoxied onto a vertical surface has enough holding power to hold just about anything youd put in a 20fter. Can drill and tap it just like aluminum but no corrosion issues. Just have to plan out the locations.
Not sure im following the helm plan, why not use glassed coosa pieces like the stern?
Ill try to get some pics of g10 mounting stuff…
If you endorse G10 then I won't question it and order some up. How thick? I think the heaviest item will be the dual bank battery charger.
My thinking with the Coosa is it is already 3/4" thick. Adding a couple of layers of glass and it is getting pretty thick and taking up valuable real estate. Also, I am running low. I could try patching together a bunch of the scraps. I was just thinking I have enough material to make the frame and I could make panels of straight glass to complete the box. I do have some of the Carbon Core honeycomb leftover I could use and it is economical enough to order and ship more if needed. Hmmmm...
