Old 11-11-2021, 07:45 PM
KenB KenB is offline
Originally Posted by JBASS02 View Post
Does anyone have any suggestion on how I should glass outside corners. It seems like any way I cut the glass I still end up with an air bubble at the corner? Should I just fill it with thickened epoxy and forget about it?
Sand back the old glass until there are no air bubbles or edges, Cut a small 2" cap piece of 6oz, then thicken epoxy (fibers and the antisag stuff), and use a chip brush (cut the bristles down to half an inch or so). 10 oz doesnt really go around 90 degree corners, it will pop up unless you roundover the edges with a 3/8 router, or 40 grit sander.
Having written all that, I noticed you fared out behind your wheel... I didn't even fare the inside weave on my console, so I shouldn't be giving you advice!
