Old 01-12-2022, 04:58 PM
Howzit, Connor! I hear you. I initially decided to hold off b/c I have the oil on it’s own heat exchanger. And they don’t have an oil temp gauge in my set. Could I repurpose a water or head temp one? Probably.
I bought a new mercury 63832a1 to go on just the oil. It just came in yesterday. Still waiting on the one for power steering.
My goal was to get this running and then fine tune. I’m more on the side of oil pressure and coolant temp gauges as vital. I read somewhere on the LS you’ll stretch your head bolts and mess up your gaskets on an engine overheat before the oil breaks down… don’t ask me where now…
But with your suggestion I could put one on there and add an Hobbs meter and that would take me back to factory gauge setup with 4 on each side…so I’ll likely do that. With the oil filter relocation kit and cooler kit it should be a simple thing to do.
So here’s a mock-up on mdf. I’ll cut it out in template, break in engine and order the other gauges and install in boat eventually.
