Old 02-07-2022, 06:33 PM
Keep an eye on that thru hull if it's original. They were threaded plastic from the factory. Easily cracked due too stress between the inner liner & outer hull allowing water intrusion to the bilge... No Insulation between liner & hull, upper nor under. I replaced mine with S/S Gem make utilizing a drain plug inside.
