  #38
Old 02-09-2022, 05:25 PM
Much better plan brother. Get after the basic stuff then work on the other stuff between times. Get that oscillating saw going and save bulkheads as can for templates.
Bulkhead's look about like mine did. And what Connor said. Plenty of room to work under there but gonna be sore, cuts, bruises, itchy is just part of it. Herons pics are gone but he made a small bulkhead and a platform with a bilge pump using pink foam and epoxy. I miss his pics that was a wealth of knowledge.
I’ll give you 2 of my big regrets
Better Drain tubes under deck
Rigging pvc tubes under deck
As we discussed raise the center stringer and Add small bulkheads between stringers for a platform for the fuel tanks.
Id suggest only do 1 bulkhead at a time they are toast but they do add rigidity and you don’t want it twisting on you.
Good luck templating. Cardboard worked best for me. Cardboard to 5mm board sanded and shaped. Then cut out coosa. And glassed in.
