FWIW:
1.Line your roller pans with heavy tin foil. That way you dont have to clean them after each step.
2.Make sure you clean the roller with duct tape or a tack rag first.Lots of hidden stuff on them from the factory.
3.Have extra rollers & brushes than you think you will use. Ready to go. Drop one on the ground a ¼ way thru your job you'll be glad you did.
4. When rolling verical , roll from the bottom up not the top down. This will prevent runs.
Good luck
