Originally Posted by JUST JOHN
^yeah, trying to soak all these great tips up like a sponge... for future projects. Thanks everyone!
FWIW
I’m not a pro at painting or Gelcoat but have managed to get thru a few projects .In doing so I found a lil trick that has helped me in sanding out a run or two .I have a bad habit of not only sanding the top of the run but also thru the area around the damn thing—I found if get some dollar store adhesive shelf paper and put it over the run I can sand off the top of the run and when it gets to the point that the run is flat with the paper and the paper it tapered a bit I can pull off the shelf paper and then fine sand without burning the surrounding area
