  #25
Old 09-15-2022, 11:46 AM
See if you can pop off the delam stuff with a chisel and wedges, save ya alot of grinding.
I like to glue up the core to full thickness before putting in the boat. Just epoxy and cabosil between the sheets. It keeps everything straighter that way. Definitely need something to keep the skin in "plane" while you glue it in. Make sure youve got air relief holes thru the sheets in each step.
Looks like someone wiped bondo all over the original gelcoat and painted right over it?! Mess for sure.
