Steel- been looking for that at my local HF they haven't had it in stock. Good to know it will last more than a day.
Pete-send me a PM your welcome to come over. What stage is yours at? Would love to see yours too and bounce some ideas off you. Maybe after all the destruction is done and its tucked away for the winter build.
Switching it up from the grinder tonight- pulling foam out of the stringers. Starboard was soaked- expected that there was a 2" x 2" square missing from the top of the stringer. Port wasn't bad, actually made it a lot harder to remove the foam when its dry.
Both stringers look like they used the wood bulkhead under the casting platform for an "end". Mine was rotten and caused a bunch of delam in the starboard side. Hopefully the rest of the stringers are fairly intact.
Need to get al this foam out, then tear the wood out of the casting deck.Is the bottom inside the casting deck storage wood cored?
