Re: Transom Mounted Transducer Placement
Brad,
"<< Shoot-Thru-Hull Mount
In this installation, the transducer is bonded to the inside of the hull with epoxy. Ideally, the transducer is placed in the aft third of the hull close to the centerline. The signal "shoots through" the hull with some loss of signal strength. This installation must be made in an area of the hull that is made from solid fiberglass, with no air bubbles or separated layers. If the hull is of multi-layer or "sandwich" construction, you will have to remove the inner layer of fiberglass and the wood or foam core to expose the outer layer of the hull. This type of mount is recommended only with 192 or 200 kHz transducers."
This is right from Lowrance's website.....
John
John
I support the "Hot Boat = Hot Chick" theory.
